UHD Converter UHD to Blu-ray Converter module
    Hi
    i have used the copy module to create the iso. is it possible to create an mkv file from the ISO file while retaining the DTS:X audio
    You can use Ripper mode, select profile mkv.passthrough or profile mkv and set it to "copy audio" in Advanced Settings window to have a try.
