LG BP60NB10 Drive and 4K error
    Optical Drives LG BP60NB10 Drive and 4K error
    I have tried to rip Ghostbuster II using this drive but get the drive is not supported. This was a drive that was listed on there that was compatible. I tried on Mac and PC with the same error. Any help is appreciated. If you have a specific model that works for you please let me know. I don't know if the firmware is the issue and if it is not sure if I would know how to change the firmware (I also tried Close Encounters of the 3rd kind and has the same message)
    check the drives firmware, see if it has firmware version - GH01 - https://www.dvdfab.cn/4k-uhd-drives....ID=productpage
      Can you tell me where to find.. I look at properties. I also cannot find GH01 Firmware or even Model BP60NB10 on lg's website
        try right clicking on your dvd drive - click properties - Hardware the firmware should show.
          try right clicking your dvd drive - click properties- Hardware, the firmware should show
