It's stuttering problem in BD-R 50G
    UHD Copy It's stuttering problem in BD-R 50G
    I found this problem in "Ant-man and the wasp UHD and The Shallows UHD
    When I choose only sound (eng,thai) and subtitles (eng, thai) and use dvdfab copy. Output size less than 50G. No re-encoded on both.
    When i burn in bd-r 50G and play them. They have stuttering problem in some sence. But no problem when i choose dvdfab copy 25G.
    So i think, It's bitrate too high for BD-R 50G.
    Can you fix this?
    Hi gantz,
    Please post the related dvdfab_internal.log file and fabcheck_internal.log file.
    Please specify the player you used for playback.
    Thanks,
    Mona
      This is log file for underworld blood wars UHD remux
      Original size about 40G
      I choose 50G in dvdfab copy fulldisc and main movie But log file show 100G.
      Both does not re-encode file. Burn it BD-R 50G and play on LG UP970.
      It has been stuttering problem.
        This is log from The Shallows UHD.
          I think it's because too high bitrate for BD-R 50G. My opinion in uhd case you need to check bitrate on uhd copy not only size. When original size less than 50G but bitrate too high, it will be stuttering problem.
            Any Update?
              Still waiting.
                Still waiting.
                  I'm sorry for the trouble.The problem has been received and we are trying to reproduce it.
                    Hi gantz,
                    Is there any similar problem when playing on PC.
                    Thanks,
                    liuhui.zong
                      no problem on pc.
                        We've played back the result on OPPO Player, we don't have the same issue. Please update to the latest version to try again.
                          I don't know lattest version can fix this problem. I believe it can't fix if it still copy mode not video reencoded.
                          Now I can fix this problem by change "Writable Media (50G) Size" in program setting from 46100 (default) to custom (minimum = 43000).
                          If size less than 43000, I use another program.
