First can I check on when the Buffalo BRUHD-PU3 will be supported? I have one ready to downgrade.
Hello thanks for the UHD drive tool... it was very useful. I was able to downgrade a WH16NS60 drive to fw 1.0 and was using it to view disks. However the computer I was using had a power supply problem and the motherboard and drive are both not working any more.
Anyway I got another WH16NS60 and I am trying to downgrade it, using a different computer. It has an Asus P9X79 motherboard. I can put it into IDE mode, but only enhanced (compatible does not boot windows).
When I try to downgrade the drive, it freezes up at various stages. Usually it gets to the end of "backing up old firmware" then windows freezes up.
Sometimes it gets a little past that.
One time it got as far as "writing new firmware", but then it said it failed and was restoring old firmware. That didnt work either. Drive was on BOOT version firmware. I was able to use the LG firmware update utility to put it back on 1.01 and get it working again though.
If i were to try like 100 times I imagine it might eventually work, but the continuous freezes take too much time and there is disk corruption that occurs. Windows wants me to run chkdsk after each time the system freezes up and sometimes it finds errors. Takes a long time.
Could the following steps help?
-change to windows 10 (currently 7), though i would prefer not to
-update BIOS (I usually avoid doing this unless there is a reason, such as this)
-make a windows PE boot usb drive and run the utility from there, if possible
-wait for a new version of the utility
-something else?
ASUS P9X79 motherboard
BIOS version 3305, 12/25/2012 build date (latest stable BIOS from 4-2014)
Thanks
-something else?
Thanks
