Waterworld - No DTS-HD Master/7.1 DTS:X for Extended Edition.
    UHD Ripper Waterworld - No DTS-HD Master/7.1 DTS:X for Extended Edition.
    There's two editions on this UHD disc, the Theatrical and the Extended and DVDFab is only picking up DTS-HD Master/7.1 DTS:X for the theatrical and not the extended. Even the standard Blu-ray has DTS-HD Master for both so there should be no reason why the Extended Edition on the UHD disc shouldn't have DTS-HD Master/7.1 DTS:X except that it's not being properly decrypted. As you can see in the screen capture.
    Here's the entire UHD disc structure except for the M2TS files. The dvdfab_internal.log file is in the root directory.
    Purchased at AMAZON
      From the BDInfo, the extended edition has the DTS audio track only, but the normal version has the DTS:X audio track.
      Please open the disc with Passkey and check the media info of the extended version "00096.m2ts" from the disc directly.
      Download mediainfo tool from the link:
        Passkey isn't working, it completely destabilizes my computer and makes Explorer unresponsive and it forces me to perform a hard power shutdown.
          I had to install it on a different computer and this is what it has. As you can see it does have DTS-HD Master/7.1 DTS:X.
          General
          Complete name : E:\BDMV\STREAM\00026.m2ts
          CompleteName_Last : E:\BDMV\STREAM\00096.m2ts
          Format : BDAV
          Format/Info : Blu-ray Video
          File size : 82.7 GiB
          Duration : 2 h 56 min
          Overall bit rate mode : Variable
          Overall bit rate : 67.2 Mb/s
          Maximum Overall bit rate : 109 Mb/s
          Video #1
          Menu ID : 1 (0x1)
          Format : HEVC
          Format/Info : High Efficiency Video Coding
          Commercial name : HDR10
          Format profile : Main 10@L5.1@High
          Codec ID : 36
          Duration : 7 s 925 ms
          Width : 3 840 pixels
          Height : 2 160 pixels
          Display aspect ratio : 16:9
          Frame rate : 23.976 (24000/1001) FPS
          Color space : YUV
          Chroma subsampling : 4:2:0 (Type 2)
          Bit depth : 10 bits
          Writing library : ATEME Titan File 3.9.0 (4.9.0.0)
          Color range : Limited
          Color primaries : BT.2020
          Transfer characteristics : PQ
          Matrix coefficients : BT.2020 non-constant
          Mastering display color primaries : BT.709
          Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
          Maximum Content Light Level : 986 cd/m2
          Maximum Frame-Average Light Level : 180 cd/m2
          Video #2
          Menu ID : 1 (0x1)
          Format : AVC
          Format/Info : Advanced Video Codec
          Format profile : High@L4.1
          Format settings : CABAC / 4 Ref Frames
          Format settings, CABAC : Yes
          Format settings, RefFrames : 4 frames
          Codec ID : 36
          Bit rate mode : Variable
          Maximum bit rate : 35.0 Mb/s
          Width : 1 920 pixels
          Height : 1 080 pixels
          Color space : YUV
          Bit depth : 8 bits
          Scan type : Progressive
          Audio #1
          Menu ID : 1 (0x1)
          Format : DTS
          Format/Info : Digital Theater Systems
          Format profile : X / MA / Core
          Muxing mode : Stream extension
          Codec ID : 134
          Bit rate mode : Variable / Variable / Constant
          Bit rate : Unknown / Unknown / 1 509 kb/s
          Channel(s) : Object Based / 8 channels / 6 channels
          Channel positions : Object Based / Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
          Sampling rate : / 48.0 kHz / 48.0 kHz
          Frame rate : 93.750 FPS (512 SPF)
          Bit depth : / 24 bits / 24 bits
          Compression mode : / Lossless / Lossy
          Audio #2
          Menu ID : 1 (0x1)
          Format : DTS
          Codec ID : 130
          Bit rate mode : Constant
          Bit rate : 768 kb/s
          Channel(s) : 6 channels
          Channel positions : Front: L C R, Side: L R, LFE
          Sampling rate : 48.0 kHz
          Bit depth : 24 bits
          Compression mode : Lossy
          Stream size : 967 MiB (1%)
          Audio #3
          Menu ID : 1 (0x1)
          Format : DTS
          Codec ID : 130
          Bit rate : 768 kb/s
          Bit depth : 24 bits
          Audio #4
          Menu ID : 1 (0x1)
          Format : DTS
          Codec ID : 130
          Bit rate : 768 kb/s
          Bit depth : 24 bits
          Audio #5
          Menu ID : 1 (0x1)
          Format : DTS
          Codec ID : 130
          Bit rate : 768 kb/s
          Channel(s) : 2 channels
          Channel positions : Front: L R
          Bit depth : 24 bits
          Text #1
          Menu ID : 1 (0x1)
          Format : PGS
          Codec ID : 144
          Text #2
          Menu ID : 1 (0x1)
          Format : PGS
          Codec ID : 144
          Text #3
          Menu ID : 1 (0x1)
          Format : PGS
          Codec ID : 144
          Text #4
          Menu ID : 1 (0x1)
          Format : PGS
          Codec ID : 144
          Text #5
          Menu ID : 1 (0x1)
          Format : PGS
          Codec ID : 144
          Text #6
          Menu ID : 1 (0x1)
          Format : PGS
          Codec ID : 144
          Text #7
          Menu ID : 1 (0x1)
          Format : PGS
          Codec ID : 144
          Text #8
          Menu ID : 1 (0x1)
          Format : PGS
          Codec ID : 144
          Text #9
          Menu ID : 1 (0x1)
          Format : PGS
          Codec ID : 144
          Text #10
          Menu ID : 1 (0x1)
          Format : PGS
          Codec ID : 144
            You need to check the media info of 00096.m2ts (it's the extended version), not the 00026.m2ts.
            Click image for larger version  Name:	8-5-2019 6-29-32 PM.png Views:	1 Size:	35.2 KB ID:	370896
              Wilson.Wang Your evidently correct, even though I can't check because Passkey completely destabilized my computer and I have to restore Windows due to instability issues. I found this on a review site about the UHD disc.
              "The UHD disc does offer under the "Bonus" tab the opportunity to watch the film in its extended version (2:56:01) in 1080p/SDR/DTS 5.1 only, not in 4K/HDR."
              What a let down, I wouldn't have even bought this had I previously known.
