The Doors - ISSUE
    UHD Ripper The Doors - ISSUE
    It seems like it decrypts it correctly but it doesn't, the entire output file the audio and video are out of sync. There are two versions on the disc, the standard which is 138 mins and the Final Cut which is 140 mins.
    The Contents of the disc excluding the Stream directory.
    Below are the log files.
    Purchase Link
    Hi AcIDc0r3, we've received your feedback and need some time to check, we will update you ASAP.
      Mona Any new news on this?
        We are waiting for our disc, please kindly wait, thank you.
          Purchase Link
          We got our copy of the disc, but we encounter a read error which cannot be ignored and we will have to exchange it for a new one, and it will take longer time.
          We also notice in your log file that there was read error:
          2019.08.15-13:32:21: info: processing source(00004.m2ts)
          2019.08.15-13:45:51: read error: 11 40512 15476159 5959867 4
          2019.08.15-13:45:51: OnDVDInfoNotify: error type 1
          2019.08.15-13:46:51: read error filling 0: 11 40512 15476159 5959867 4
          2019.08.15-13:46:51: error: demux sync error, pos:12193616064
          Please clean the disc, set it to ignore all error in DVDFab v11045 to have a try and feedback. Thank you.
            Mona Ok so I had ordered another one but this time instead of the German edition I bought the UK edition and the same thing, so I tried as you suggested and turned on "Ignore All Read Errors" and still, that didn't help either. Hopefully when you all get your replacement copy that you can find a solution to this situation.
              Any word on this yet Mona ?
                Might be qorth trying the trial version of DeUHD or MakeMKV and see if they can read the disk.
                  Oh it can read the disc just fine, it just can't get the A/V sync'd correctly.
                    We have not yet received our new copy.
