Odd behavior with Pacific Rim uprising
    UHD Ripper Odd behavior with Pacific Rim uprising
    When I try to rip Pacific Rim Uprising, the disc is read to the configuration screen where you can select the profile, audio tracks, etc... When I try to start, it says to insert the disc.
    It doesn't matter how fast I try to do it.
    I included the internal.log.
    Did you load it to Copy mode and then switch to Ripper mode?
    The log file doesn't contain much info.
    Please exit the disc, run DVDFab, switch to Ripper mode, and then input the disc to try again. If still have same problem, please shoot a video to show us. Thanks.
