Has anybody else had problems with Hellboy 2004? The first disc I recieved was recongized and DVDFab tried to rip it but got errors, so I asked Amazon to send me a new copy. I had exactly the same problem, errors that prevented ripping. At first I assumed there had been a problem mastering the disk, but I decided to let MakeMKV have a go and it was able to rip the second disk without a problem, so I'm wondering if there's some funky new protection scheme on this disk.
Hellboy (2004) Problems
Originally posted by Mona View PostThank you for the info and report, we are checking it, will update you as soon as possible.
>>>UPDATE: we need a buy URL for getting the same copy of the disc Hellboy (2004), thanks.
The decrypt key is correct on server, we will also check it when we get the disc. It's still on the road.
WilsonPlease post your logs the default location is:
