Burning issue
    UHD Copy Burning issue
    When burning to a BD-DL using DVDfab internal engine, I am having a reading problem with both of my UHD players. Data issues occur about 2/3 of the way. If I create an iso file and burn with Nero, the discs are perfect. Is there a fix in settings?
    What are the brand and model of your players?
    Also, please post the related log session of the process, we need dvdfab_internal.log file and burn logs, thank you.
      The problem turned out to be a bad batch of discs. No mater which recording speed was selected, the lockup occurred at the point of layer change.
