Uhd rip inconsistant
    I've used UHD ripper lots of times and generally when I create an output of say 10,000 kbps per movie, this obviously changes based on the length of the movie, so when my settings say output should 8.7gb for a 2 hour movie, , why does the file when it is eventually produced much less than this ?
    for eg
    Hacksaw Ridge is 2 hours and 19 mins long - i set the bit rate at 10,000 output should be 10415mb just over 10gb
    so why all of a sudden is dvdfab spitting files out at only 8.4gb
    I am using MKV h265 10bit uhd ripper tool , i am preserving the chapters and downgrading the audio to AAC.
    its only started doing it, all my other files seem fine , i've done over a 100 movies and all the other ones match up to what they should be output based on bitrate.
    Hello, we will run some tests and get back to you.
    Meanwhile, please provide dvdfab_internal.log file and fabcheck_internal.log file. You can refer to this post for how to send log via DVDFab and post feedback ID.
    DVDFab Forum - Log Files Help Our Developers Troubleshoot Your Problems Quickly
