Hi ,
Just wondered if anyone had come across this before , successfully ripped Spiderman far from home down using the single layer dolby vision mp4 file rip, and it worked perfect.
So I thought I would try Scary Stores To Tell In The Dark and Grease , and they both worked without errors, but when I played back on my Oppo player with LG 65" Tv , it has different coloured lines all the way through, you can just make out the picture and the sound is fine.
Found it strange as Spiderman far from home was perfect.
