DVDFab makes UHD discs with wrong chapters
    I try to explain the procedure.
    Load UHD movie (no mather what title)
    Export movie only, but select the last half of chapters. Let say the disc has 40 chapters, so then export 21-40.
    Result is that the disc has only 1 chapter instead of 20.
    It does work with the first part of the disc, like 1-20
    The weird thing is that this does work fine with DVDFab 10216 or 11004. I know that it is not working with 11065 and 11077.
    Can you please find out what went wrong after 11004?
    Thank you for the report, I will have the developer check.
      Hello, we are unable to reproduce the issue of "export 21-40 from main movie title got only 1 chapter" with the latest version of DVDFab, the result contains all the content it should have.
      1. Please specify the movie you tried.
      2. By "the disc has only 1 chapter instead of 20",
      --- I want to confirm, do you mean that you playback the output disc but got only the first chapter or that the result file contains all the content but displaying as one chapter?
        Sorry for the very late respons,m there were some issues.
        1. all movies
        2. all content displaying as one chapter.
        There must be a difference because all movies go well on 11004 and earlier.
