This happens with a couple of disc I have. The current example is Ready Player One.
When I use the dolby vision profile with 1 layer, The video gets corrupted randomly.
The affected frame becomes full of white blocks. Within 2 or 3 frame, the video is back to normal.
If it happens too often, the audio get unsynched. DVDFab report the task successful.
The two layer version is fine. The same with the mkv passthrough version.
To test the difference, I created 3 task (one for each type) that I runned in batch. This would allow creating the three types without touching the disk and risk introducing smudges on the disc surface.
I have included the internal log.
