Picture Problem
    UHD Copy Picture Problem
    Feedback ID 9426791
    Movie : Bombshell BD
    I created main movie 25G with DVDFAB 11.1.0.0. After process done, I play on DVDFab Player6 and TMT6. Video was corrupt and a lot of mosaic
    Click image for larger version  Name:	c910e144f7166e1891dd7196c3c3525a.png Views:	0 Size:	117.3 KB ID:	384131
    Did you try not set "CUDA GPU acceleration for Lightning-Shrink enabled" to compress the movie to BD25 and see the result?
      Set no cuda gpu. It can fix this problem but it took time almost 2 hours.
        The compression amount as well as the gpu doing the encoding has a drastic effect on the amount of time it takes to encode. Too much compression and you will get those artifacts and without knowing what kind of gpu you are using its a guess as to that being the reason for the 2 hour encode time.
