Dolby Vision Removal When Using UHD Copy
    UHD Copy Dolby Vision Removal When Using UHD Copy
    just wanted to ask, is there a way to remove the dolby vision video part from the UHD 66 or UHD100 when compressing down UHD 25gb Full Copy.
    example extracted below from a DVDFAB scan i did afterwards using BDINFO
    MPEG-H HEVC Video 12118 kbps 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / HDR10 / BT.2020
    * MPEG-H HEVC Video 8033 kbps (39.86%) 1080p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / Dolby Vision FEL / BT.2020
    Them extra 8033 kbps i would rather use for my HDR10.
    Thanks
