Blu-Ray to UHD Converter Issue
    UHD Converter Blu-Ray to UHD Converter Issue
    Hi Team,
    Why has the blu-ray to UHD converter all of a sudden started merging titles , so if i add one title , adjust settings , then add another it adds it onto the one i've just added instead of starting a separate conversion.
    so on this screenshot attached I have already started Spawn and its 7% gone , i've added Tomorrow never dies and its just trying to merge it?
    Help please Click image for larger version
Name:	Screenshot 2021-05-09 071438.png
    If this is part of the design..
    The question i have is , why can't you load multiple tasks of Blu-Ray to UHD , just like you can for UHD COPY movie only etc?
      After you start a process you add a new task, it will be "merged", it's a bug. We will check. Sorry for that.
