Hello everyone!
Congrats on the great software! Is the first one that covers my need of fitting UHD backups ~70GB into BD50 because BD100 are too expensive.
I have two questions though:
1) Is there any way of control with a little bit of detail how the conversion is done when you create a UHD disk? I can only select a target bitrate but nothing else.
2) When I select lets say 35Mbps of bitrate in conversion. That is Constant Bitrate, Máximum Bitrate or Variable Bitrate with 35Mbps of mean?
Also, the estimation of final size of the file is kind of misleading, I need to set it so the software estimates ~52GB for it to be ~46GB. Am I doing something wrong? How can I improve this?
