My copy of Scream in UHD keeps getting read errors. I've checked the disc and the surface is pristine (literally went straight from the case to the drive, never played). I'm attaching the log. I hit retry a few times before cancelling out.
Read errors with Scream (UHD)
Chaos Walking UHD read error problem. get read error problem on clone mode and full disc mode.Originally posted by Mona View Post
The developer needs the log file to help check it out, please post it, thank you.Attached Files
The developer checked the log file, and the read error appeared at 20% of the cloning process, so it could be a disk issue rather than a copy-protection issue.Originally posted by gantz View Post
If you have another drive, you may use it to copy the disc again and see if it will make a difference.
Or you can use Passkey to create a P-ISO file, and then use DVDFab 12 to load the P-ISO file to try again and see the result.
Create ISO with Clone mode and keep protect. and then use Full disc mode with ISO.Originally posted by Mona View Post
It works. Thank you.
