UHD Copy - Forced subtitle issues?
    When UHD Copying the Movie Only of the War for the Planet of the Apes disc I don't see in the resulting ISO the Forced Subtitles of when the Apes use sign language. I have chosen "Always display only forced subtitle" in the Common/Conversion settings. During the copying I see that there are 3 EN subtitles to choose from. If I select only one at a time, or all of them, I still don't see the forced subtitles.
    What am I doing wrong?
    I also get the Narrative audio over the full video, how do I not record that or turn it off?
    Please choose all subtitles to copy and switch the three EN subtitles see which one is the subtitles for the Apes use sign language.
    Please make sure to open subtitle through your player.
    For narrative audio , the audio track you chose is a cause of this issue. Normally there are several audio tracks in the main movie, you must have checked the audio including narrative/description voice to copy/convert. Please select another audio like AC-3/5.1, DTS/5.1 or more higher level to see if you can get rid of this annoying narrative/description voice.
      It all worked out as you suggested. Unfortunately you need to perform the Copy routine with each subtitle until you find the correct one.
