UHD Ripper - No Audio Track
    UHD Ripper UHD Ripper - No Audio Track
    When the UHD disc is read, no audio tracks are populated in the audio track dropdown, its blank with no dropdown carrot. When I try to run the rip anyway it either fails immediately or gives me the "...please insert disc..." error. The drive does not pop open at anytime, I can delete the source and reload without opening the drive, and if I close Dvdfab and reopen, the source is reloaded, with the same issue. This has happened with 5 sealed discs now (yes, I clean the disc after the first attempt) on both of my drives which I've ripped UHD discs with before. Has anyone else come across this issue?
    To confirm, do you have the same problem with other UHD movies?
    Could you please also give a previous version a try and feedback?
    Here is a download link to one of the previous versions.
      Yes I do, about 5 give me the same issue: Avatar, Iron Man 1-3 and Avengers Endgame. I just ripped a new (not the ones listed) UHD today with no issues on 13.0.2.7. The rollback didn't help.
        UPDATE: We've updated the UHD part, please kindly run the latest version of DVDFab to try it again and see the result.
