AV-200 Bul-ray
    AV-200 Bul-ray
    There's a lot of issues here on this forum for the av-100. I've only had my unit two days now and it's the best media player I've owned. Right out of the box I upgraded the firmware from 3.1.1 to 3.1.2 and also updated XBMC software. I adjusted the setting per Vidon.me web instructions. I really like the custom zoom feature. I use it exclusively for viewing my movies all in iso format. There's so much I could say about what I like about this unit, lets start with what I haven't figured out so far. I like to see the menu for my movie before I press play, like a preview. I haven't got any bul-ray iso movies with menus as of yet, but the ones I have got without the menu play exquisite. My other movies will play the menu only after I press play. I use XBMC thru the unit have watched my movies thru networked and usb. I did notice the usb had a very fast response time. I would still gave it five out of five stars.
    AV200 doesn't have Auto Frame Rate option, cannot set 23.976 Hz output (as well 59.94 Hz), doesn't support BD3D.
    Meanwhile there are many non-Android mediaplayers which have no such problems.
