Same here with SF 6214
The Tracker.s01e01 don't works for me in 1080p (max Bitrate 6063)
from D+ with Ad supported Plan in Germany (no Hulu, like CH)
DL fine - but encrypted
[code][Info]: "[DownloadDisney]" not find KEY_UUID
[Warning]: [DownloadDisney]" Save root.m3u failed. "
[Info]: [CefMedia] A non-intra slice in an IDR NAL unit.\r\n[h264 @ 0000018c9bc18b00] decode_slice_header error\r\n
[CefMedia] left block unavailable for requested intra4x4 mode -1\r\n[h264 @ 0000018c9bc18b00] error while decoding
.. and >100 [CefMedia] messages listed[/code]
If I select 720p (max Bitrate) it works fine
And H265 is not offered
Germania
ive the best plan (premium: 4k, no ads, atmos etc.)
so the plan is not the problem there
And just to put it out there:
These are different titles. Sometimes episodes 1, 2, 3 work, but then 4, 5, etc. don’t.
It’s completely weird and totally random.
Downloading multiple times doesn’t help either; the error still occurs.
To also clear up the myth about the offline/online installer:
I have
never ever ever had any issues with the online installer.
I’ve tried using the offline installer several times when problems occurred.
But the problems were always the same.
Why the online installer causes issues for some people, I can’t say (it could possibly be related to the internet itself—unstable connections, Wi-Fi, etc.).
However, the online installer itself is
not the problem.
The only real advantage of a clean install is that unused files are removed and the system gets a general cleanup.
