TRJ I’m sending a new log
Problem is unchanged - your connecion was closed by D+
[Critical]: [default] "QtDownloadTask::onError : errorString :Connection closed, code : 2
Now I tried with SF 6260, mkv(ffmpeg) and maximal H264 like you
via NY (vod-ftc-na-east-1.media), Houston+Phoenix (vod-ftc-na-east-2)
but don’t get vod-dsc-na-south-1 (?) like you ..
.. whatever, also s01e01 works fine for me in USA
Perhaps you should try a different region with vpn
or you have a partner login, that does not allow downloads
(I know this from Max - info)
