I am seeing the above errors mentioned but after repeated attempts downloads will start working.. but the bigger issue for me is that some programs are download the wrong audio stream.. this happens with BOTH mac AND windows versions
Example: Enterprise S1 E10 - Fortunate Son - I specified English.. but got Portugese
General
Unique ID : 248775802794330299700465637325247120461 (0xBB287A0FD4A959E98DA7C1E279D4844D)
Complete name : /Volumes/MultimediaISO/StreamFab/output/Paramount+/Star Trek_ Enterprise/S01/Star Trek_ Enterprise_S01E10_Fortunate Son.mkv
Format : Matroska
Format version : Version 4
File size : 1.47 GiB
Duration : 44 min 48 s
Overall bit rate : 4 698 kb/s
Frame rate : 23.976 FPS
Description : Enterprise must intervene when the leader of a human freighter crew sets out for revenge against alien pirates.
Encoded date : 2026-02-13 16:20:13 UTC
Writing application : mkvmerge 68.0.0 ('The Curtain') 64-bit
Writing library : libebml v1.4.2 + libmatroska v1.6.4
Cover : Yes
Cover description : cover.png
Cover type : Cover
Attachments : cover.png
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Format settings, GOP : M=4, N=48
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 4 500 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.091
Stream size : 1.39 GiB (95%)
Writing library : x264 core 164 r3085 0bb85e8
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / stitchable=1 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=48 / keyint_min=4 / scenecut=0 / intra_refresh=0 / rc_lookahead=48 / rc=2pass / mbtree=1 / bitrate=4500 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=5400 / vbv_bufsize=4500 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Color range : Limited
Matrix coefficients : BT.709
Audio #1
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Bit rate : 125 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 40.0 MiB (3%)
Language : Portuguese
Default : Yes
Forced : No
Audio #2
Format : AAC LC
Codec ID : A_AAC-2
Bit rate : 125 kb/s
Default : Yes
Forced : No
Type : Cover
Title : cover.png
Format : PNG
Format/Info : Portable Network Graphic
Compression : Deflate
Muxing mode : Attachment
Color space : RGB
Bit depth : 8 bits
Compression mode : Lossless
Stream size : 824 KiB (0%)
