DVDFab Forum - iTunes Rental
iTunes Rental
  • DRM Removal for Movies iTunes Rental
    I was curious to see if this would work so I rented a movie I already own and ran it through dvdfab. Now it does work but with 2 problems. The media type remains "Home Video" instead of changing to "Movie" so iTunes will only see it as a rental unless you change the attribute. Easy fix but the second problem is a little more difficult. If you start the movie from the beginning there is no audio. If you pause the movie and then unpause, it works flawlessly. Any ideas on why this would happen?
  • #2
    Thanks for posting. The QA team needs the files as below:
    1. /Music/iTunes/iTunes Music Library.xml
    2. drm_internal log and dvdfab_internal log
    The default location for log file is: C:\Users\User Name\My Documents\DVDFab11\Log
    Thanks in advance!
    DVDFab log default location:
    DVDFab Player 5:
    • #3
      For some reason it won't let me upload the itunes library file. It keeps erroring out. Is there another way?
      • #4
        Any ideas?
        • #5
          Hello, please update to the latest version of DVDFab, try again, and then upload the latest drm_internal log and dvdfab_internal log file.
          As for the iTunes library file, please try to zip it and upload again, thank you.
          For Windows: C:\Users\User Name\Documents\DVDFab11\Log
          For Mac: Finder>Documents>DVDFab11>Log
          DVDFab Player 5:
          For Windows: C:\Users\User Name\Documents\DVDFab Player 5\Log
          For Mac: Finder>Documents>DVDFab Player 5>Log
          Guide for adding attachments in a post
          --Please use attachment button to attach your most recent log files.
