DVDFab Forum - DRM Removal does NOT save changed "save to" location
instagram takipci satin al - instagram takipci satin al mobil odeme - takipci satin al
bahis siteleri - deneme bonusu - casino siteleri
bahis siteleri - kacak bahis - canli bahis
goldenbahis - makrobet - cepbahis
cratosslot - cratosslot giris - cratosslot
istanbul escort - çapa escort - şirinevler escort - avcılar escort - şişli escort - avrupa yakası escort - şirinevler escort - halkalı escort - beylikdüzü escort - mecidiyeköy escort - ümraniye escort - adana escort malatya escort
film izle - film izle
    We cannot reproduce the problem. Which DRM version are you using? And what is your operating system and version?
    You can right-click on DVDFab to run it as Administrator to try again.
      dvdfab 11.0.5.4, windows 10 Home version 1903. It allows me to change it, but next time I run the program, the value I entered does not show. I will try to run as admin.
        Tried running as admin, still did not save "save to" location
          this is the same for all versions of the drm removal tool, i've never had it save the locatio i use, but the main app lets me change when do a dvd or bluray
            Still broken in 12.0.4
              DRM Removal for Audio "remembers" the last used output location. DRM Removal for Video does not, and instead goes to the DVDFab save location.
                We will check again.
                  if you manually edit the xml file and enter the location, it works next time you load the app but then reverts back to default location
                    What file and its location, please. It sure would be nice if DVDFAB fixed the issue!
