Followwed downgrade thread but still issues
    DRM Removal for Movies Followwed downgrade thread but still issues
    Last year started seeing issues with the drm removal off the product, so not used it for a while to see if it got updated and was now working
    So today updated to latest version of dvdfab and still no go, found the instructions about installing an earlier version of which i done after removing all versions of itunes and dvdfab, rebooting pc to ensure all done reinstalled itunes using the link on the forum to install an old version then installed the latest version of dvdfab and rebooted my pc again
    On starting dvdfab and telling it to perform the conversion it opens itunes then that's it, 30 minutes later not moved on - cancelled the rip, ensured drmremoval, dvdfab and itunes all allowed to run as administrators, yet same issue
    Any ideas or most I wait and hope that they release an update this month?
    try what's posted here in the first post - https://forum.dvdfab.cn/forum/dvdfab...or-drm-removal
      another suggestion is to create a new folder and install it in there - https://forum.dvdfab.cn/forum/dvdfab...2-10-3-support
      post #15
        update, its finally working
          as said in my original post I had followed all the instructions on this forum and as for the installing into another folder it doesn't work on windows 10 and thus reason why i had to do the full uninstall method
            Can you share what you did to get it to work? Or was it the instructions in this thread? -> https://forum.dvdfab.cn/forum/dvdfab...or-drm-removal
