DVD to DVD FAQ
This is a sticky topic.
    DVD to DVD FAQ
    Everything is a link.
    Q: Why is DVDFab giving me a message saying, "This disc contains CSS protection. This version of DVDFab cannot copy it."
    A: You have downloaded the Non-CSS version. Please download the or the .
    Q: Why is my Registration key not working?
    A: Please read .
    Q: Why am I getting errors while reading?
    A: Please review .
    Q: Why am I getting errors when burning?
    A: Please read and post the appropriate information.
    Q: Will DVDFab allow me to copy dvd's from other regions without changing the region of my dvd drive?
    A: Yes, DVDFab can copy dvd's from all regions without changing the region of your dvd drive.
    Q: What is the region code of my backup copy?
    A: DVDFab creates a dvd with of ALL or 1, 2, 3, 4, 5, 6, 7, 8.
    Q: Can DVDFab convert PAL to NTSC?
    A: No. You will have to use a separate program such as VSO ConvertXtoDVD. Developed by the same company which develops the default burning engine used by DVDFab.
    Q: How do I change the location where DVDFab saves my dvd rips?
    A: Click the Common Settings button, , click on the . From here you can change the Output Directory and Temporary Directory.
    Q: Can I combine two dvd's using DVDFab?
    A: Yes, please review the .
    Q: Where can I find the DVDFab error codes list?
    A: Right Here --> .
    Q: Windows Media Player will not play the DVDFab output. How do I play my ripped movies on my computer?
    A: You can play the video_ts folder and ISO files with many software video players. Free recommended player is VLC media player.
    Q: What is PathPlayer?
    A: gives DVDFab the ability to copy DVD content only allowed to be played on a real DVD player. In this way, DVDFab will ignore unplayable content which may contain copy protection.
    Q: Can DVDFab perform dvd-copy on-the-fly?
    A: No, DVDFab will only copy to your hard drive. Then using you can burn the files to a blank disc.
    Q: What is the difference between Full Disc and Clone Modes?
    A: Full Disc allows you to copy with different settings and the option to apply compression. Clone Mode produces a bit-for-bit copy and only outputs an ISO file or write to a blank disc.
    Q: Why am I getting Verify DVD started, Task_3 failed! Error=100?
    A: The verify feature in the VSO Burning SDK is buggy. If you want to use Verify please change your burning engine to ImgBurn.
    Q: Why does my old DVDFab version work but I can not burn using the new version?
    A: I don't know. Please read You and post the requested information.
    Q: Why does DVDFab always fail at a certain percentage when trying to backup INSERT TITLE, the disc plays fine in my dvd player.
    A: DVD drives are more picky when reading a disc. Your dvd drive is trying to read all the data, where as a DVD player will easily skip over an unreadable section. Please read .
    Q: Why does DVDFab create an empty AUDIO_TS folder?
    A: The AUDIO_TS folder isn’t needed on Video dvd's but some really old dvd players require one to be present.
    Q: Does DVDFab alter the sound quality?
    A: When using the the sound is not altered. DVDFab will not alter the audio even when applying compression.
