No matter what I tried I could not get Dvdfab10 to copy directly to my DMS. I've only owned it for a few days now and I was ready to start throwing things out of the window.
I thought I was pretty sound on how to network drives etc as nearly everything in the house is connected to either my Server or my PC for direct access to movies and music.
But after hours and hours of Googling, searching the forums I could not find a work around to get DVDFAB10 to copy directly to my DMS and I could not get my DMS to connect directly to my PC but it would connect directly to my server.
After a little bit of investigation it came to light that Microsoft had decided to automatically disable SMBv1 and use SMBv2 & v3 as the latter versions are more secure and hardware and software vendors need to update their devices etc to come into line so that they can all speak to one another again.
This was really easy to fix once I had found it.....
Basically it's as easy as 1,2,3.
Go to Control Panel > Programs and Features > Turn Windows Features on or off > check or uncheck the box for "SMB 1.0/CIFS File Sharing Support"
As I found out mine was not active after the Microsoft Fall Update as they call it.
Mine was like this.....
And ended up like this.....
Now I can access my DMS via the DVDFAB10 software for copying directly onto the DMS or I can access it via browser window and I can also connect my DMS to both my Server (Which I was able to do before) and my PC that I wasn't able to do no matter how hard I tried.
I hope this helps some of you that are experiencing the same problems I was!
Hopefully this will be made a STICKY so it's an easy to find fix on Windows OS for some people.
