Still no news....
Split feature Blue-Ray to Blu-ray
Maybe you should add addtional option for custom BD size.
At that moment DVDFab have five media size options:
BD50 1080p
BD25 1080p
BD9 1080p
BD9 720p
BD5 720p
It would be nice to add Custom BD size with ability to change size and resolution.
For instance. I want to make two BD9 discs with divided title. It is possible by compressing entire title to approx 18 GB, then divide it with external program. So I would like to compress title with DVDFab and then divide it in external program.
Of course, divide option would be nice, but at that moment Custom BD size is much, much easier to develop. Of course, in my opinion only.
I know, I can change destination size in Write options but it is not possible to set value outside predefined ranges.
ArtS
Would be nice
Just bought a licence for DVDFab and it works very well - but have to agree with the request for Split capability.
Uploading takes 40 minutes for original 30GB movie but need to write on very expensive dual layer Blu ray media - minimum cost per disk is greater than $20. I can get 25 GB BD-Rs for less than $4 each - even at 2 per movie that is acceptable.
Trouble is - uploading/compression looks like it takes over seven hours if I try the "squeeze into 25 GB disk" option... prohibitive....
Solution Found
Found a solution using tsmuxer (freeware) to split files. After using DVDFab to rip to HD, and stream file (*.m2ts) is greater than 25GB, run tsmuxer - load in playlist file (*.mpls) from PLAYLIST subdirectory...entire movie will load…
Use tsmuxer "split & cut" tab to split by size - use Blu-ray disk output option (in new directory of your choice)- when muxing is done - new Blu-ray file structure is created, but now with two stream files, each less than 25GB.
Re-run tsmuxer this time loading in just one at a time of the two new stream files as input - again set output as Blu-ray disk - specify new directory for output as well. Do this for each stream file and two new file structures are created. Use DVDFab to burn each of these to individual 25 GB disks.
Worked on everything I tried so far....
Splitting a movie onto two discs is a niche-request. Who really wants to get up and swap discs in the middle of the movie? Not me. Also, have you tried BD5 and BD9 compression yet? Even BD5 in 1080p from BD Rebuilder looks amazing on my 50" Plasma (DVDFab will support 1080p BD5's in the near future)
Also to the OP. Your whining about not getting a response after a week is rather pretentious. Fengtao has responded to ever tech support request in a timely fashion...this is a feature request (i.e. feature change/add). There is no reason for him to respond to this request until it is implemented or closed.
