Multiple Audio Tracks PLEASE
    I just checked 9.0.6.0 with mkv.h264.audiocopy and it works as expected, including chapter markers:-
    Audio #1
    Format : AC-3
    Format/Info : Audio Coding 3
    Mode extension : CM (complete main)
    Format settings, Endianness : Big
    Codec ID : A_AC3
    Duration : 27mn 46s
    Bit rate mode : Constant
    Bit rate : 448 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Stream size : 89.0 MiB (20%)
    Language : English
    Default : Yes
    Forced : No
    Audio #2
    Format : AC-3
    Codec ID : A_AC3
    Duration : 27mn 46s
    Bit rate : 448 Kbps
    Bit depth : 16 bits
    Language : Italian
    Default : No
    Forced : No
    Audio #3
    Format : AC-3
    Codec ID : A_AC3
    Duration : 27mn 46s
    Bit rate : 448 Kbps
    Bit depth : 16 bits
    Language : Czech
    Default : No
    Forced : No
    Text #1
    Format : VobSub
    Codec ID : S_VOBSUB
    Codec ID/Info : The same subtitle format used on DVDs
    Language : English
    Default : Yes
    Forced : No
    Text #2
    Format : VobSub
    Codec ID : S_VOBSUB
    Language : Italian
    Default : No
    Forced : No
    Text #3
    Format : VobSub
    Codec ID : S_VOBSUB
    Language : Dutch
    Default : No
    Forced : No
    Text #4
    Format : VobSub
    Codec ID : S_VOBSUB
    Language : Czech
    Default : No
    Forced : No
    Text #5
    Format : VobSub
    Codec ID : S_VOBSUB
    Language : Hindi
    Default : No
    Forced : No
    Text #6
    Format : VobSub
    Codec ID : S_VOBSUB
    Language : English
    Default : No
    Forced : No
    Menu
    00:00:00.000 : en01)00:00:00:000
    00:06:18.000 : en02)00:06:18:000
    00:12:24.000 : en03)00:12:24:000
    00:16:39.000 : en04)00:16:39:000
    00:23:40.000 : en05)00:23:40:000
