I am currently using the latest ver of DVDFab and have noticed, that while using the DVD Ripper, under the "Customized" tab, I change settings to meet my preferences however when the program closes, or I insert a new disc, the some of the settings go back to the default, even though I've saved the profile as my default and have 'checked' "Apply to All".
It would be a nice feature that when you create a new profile (or tweak an existing one) under the DVD Ripper, you be able to rename it to something you know (i.e. for different applications), and that all the settings are exactly the way you have them instead of saving the profile, "over-writing" the profile there and having the settings change.
Thank You
Thank You
