DVDFab Forum - decoding hevc 8 bit and 10 bit
instagram takipci satin al - instagram takipci satin al mobil odeme - takipci satin al
bahis siteleri - deneme bonusu - casino siteleri
bahis siteleri - kacak bahis - canli bahis
goldenbahis - makrobet - cepbahis
cratosslot - cratosslot giris - cratosslot
istanbul escort - çapa escort - şirinevler escort - avcılar escort - şişli escort - avrupa yakası escort - şirinevler escort - halkalı escort - beylikdüzü escort - mecidiyeköy escort - ümraniye escort - adana escort malatya escort
film izle - film izle
    DVDFab (UI/General) decoding hevc 8 bit and 10 bit
    Hello, you could replace the following 8-bit and 10-bit hevc decoding:
    --preset medium --ctu 32 --rd 3 --no-rdoq-level --no-psy-rdoq --ref 3 --b-intra --no-fast-intra --keyint 250 --min-keyint 23 --rc-lookahead 20 --bframes 4 --b-adapt 2 --slow-firstpass
    with the following two?
    --preset medium --ctu 64 --rd 4 --no-rdoq-level --no-psy-rdoq --ref 3 --b-intra --fast-intra --keyint 250 --min-keyint 23 --rc-lookahead 20 --bframes 4 --b-adapt 2 --slow-firstpass
    --preset slower/very slow --ctu 64 --rd 4 --no-rdoq-level --no-psy-rdoq --ref 5 --b-intra --fast-intra --keyint 250 --min-keyint 23 --rc-lookahead 40 --bframes 8 --b-adapt 2 --slow-firstpass
    thanks
    Hello, here are the additional minimum settings without making coding too heavy as long as fast intra is enabled along with the b-intra:
    --b-pyramid --signhide --strong-intra-smoothing --weightp --weightb --deblock -1:-1 --psy-rd 1.0 --aq-mode 3 --aq-strength 2,0 --no-cutree
      hi ,
      we test your encode command,
      your can use in advance setting , command part.
      10bit: --input-depth 10 8bit: --input-depth 8
      Or, your want it hard code in soft ?
      yours,
      For DVDFab 12: C:\Users\User Name\My Documents\DVDFab\DVDFab12\Log
        hi ,
        yours,
        just the one with your base? or even adding what I informed you
          hi ,
          yours,
          thank you but i think you should make some changes within this hevc coding of yours:
          that is:
          ctu to 64 ; aq-mode 3 ; aq-strength 2,0 ; no-cutree ; weightp ; weightb ; no-fast-intra to fast-intra ; psy-rd 1.0 ; rd 3 to rd 4 ; min-keyint 23 to min-keyint 24
            --input-depth 8 , alone fails to best set the uniformity of color and background when I increase the lighting manually with the Player, and --b-pyramid --strong-intra-smoothing --weightp --weightb --deblock -1:-1 --psy-rd 1.0 --aq-mode 3 --aq-strength 2,0 --no-cutree to which I would add other peculiarities to standardize the background at the beginning "Burlesque 2010 Bluray"
            there's a way to decide for yourself how to set, if you then find a way to make setting the choice of how to encode easier and self-editable, overwriting your string
              Hello, would you kindly have a way of checking this? thank you, with Bluray 1:1 8 Bit:
              --b-pyramid --lookahead-slices 0 --tu-inter-depth 3 --tu-intra-depth 3 --limit-tu 0 --strong-intra-smoothing --max-merge 3 --limit-refs 3 --limit-modes --me umh --subme 4 --weightp --weightb --deblock -1:-1 --sao selective-sao 4 --no-early-skip --rskip --psy-rd 1.0 --aq-mode 3 --aq-strength 2,0 --no-cutree
                --b-pyramid --lookahead-slices 0 --tu-inter-depth 3 --tu-intra-depth 3 --limit-tu 0 --strong-intra-smoothing --max-merge 3 --limit-refs 3 --limit-modes --me umh --subme 4 --weightp --weightb --deblock -1:-1 --sao --selective-sao 4 --no-early-skip --rskip --psy-rd 1.0 --aq-mode 3 --aq-strength 2,0 --no-cutree
                  this one I sent you is perfect, only I still lack a certain blurring, I believe that the result would only be if fast-intra is positive and not negative (i.e. in your settings)
                    Hello, I chose to try the 6 programs at the price of 59 dollars in the hope that within a year the command line used for ripper and converter is freer or that when you put custom whether it is crf encoding, 2 passes or abr, your settings are deleted so that in the log there are those chosen by the user. I hope that within a year, even within a shorter period, this will happen... and if that's the case, after a year I'll take the full version for life
