@feng or ting
Never had this problem with PowerDVD 9, but I'm giving up on PDVD9, too buggy.
Started using Total Media Theater 3 (v3.0.1.170), like it a lot, just a couple of minor issues for me.
But here's the problem with running TMT3 and DVDFab at the same time (i7), and I'm only extracting. I hit the eject button on TMT3 while playing a folder from the HDD. Low and behold the disc ejected and cycled back in while DVDFab was extracting the disc. PDVD5/PDVD9's eject never had any effect while using DVDFab, but TMT3 does.
I always thought DVDFab LOCKED the drive when extracting ? As I've never run across settings for locking the drive, is it there and I'm missing it ?
If not, it needs to be implemented like on ImgBurn .....
Regards,
AX
- Does NOT display the DVD label / ISO info in he Title Bar or the Select Source, so you don't know what DVD your playing.
- The onscreen Information does not display the Audio Channel info, whether it's DTS, 5.1 or 2.0, previous ver did, lost it when I upgraded.
Regards,
AX
