I use TMPGEnc (as well as DVDFab) and have a 'Spurs Engine Plug-in' which uses a WinFast encoding card for the transcoding and the time required is about 20% of what is using the CPU for this. ie., if it normally takes an hour, it takes about 10 - 15 mins with the setup.
I'm sure there are other methods to offload the work from the CPU, it would be a nice enhancement to an already great program.
- Benjamin Franklin 1706-1790
