I'm not very smart to this stuff! I've learned everything I know on this Forum!
I've been using Fab since V5, I've used every official and beta that has come out till now!
I have an old Dell Optiplex GX 260(2005), with Windows XP Pro, SP3! I have never had any problems with any D/L of any versions, just little minor problems, nothing with the programs itself!
I have an old version of IE8, and have not up-dated! All the QT's official and beta have D/L and carried over settings with no problems!
I just D/L 8095QT beta with no problems, save to my documents, then open as Administrator! I opened 8095QT and saw the new fab display loading, which looks great! Then fab open and I checked my (blue) about! Everything good!(I just have DVDCOPY) I checked my settings, all good, Also use ImgBurn!
I just copied Gremlins Special Edition, one of my old dvds! Copied and burned perfectly!, I always copy to HDD, then use ImgBurn by itself to burn copy from Full disc folder or Main Movie folder in DVDFAB folder, works great!, but my Windows XP, SP3 has never had any problems! All QT's are fine on my old PC!
I put this thread so maybe it will help others, not as how I do things, but maybe there is something to look at that might help!
If you need to look at something, maybe I can send the Info., If you can explain what you need and how to do it!, If not thats okay!
Just trying to lend a helping hand with this Windows XP SP3 problems!
The New Loader is a work of art!(nice) Stepping out will be back later!
