DVDFab Forum - My Intel Quick Sync test.
  • #46
    I using DVI but it could be HDMI maybe. How do you connect your monitor?
    • #47
      To the grafhics card-DVI!, but it also has a mini hemi connection, but it would never work!(evga geforce gtx 460 oc)
      • #48
        Not all Z68 mobo's have video on board, guess you lucked out.
        Look at this for example;
        http://www.newegg.com/Product/Produc...82E16813121641
        • #49
          Well if that is the only place to connect it to the computer then I guess it does not support the integrated graphics necessary for Quick Sync.
          • #50
            If your thinking about changing your mobo I would go with a Z77 chipset with graphics built-in. You'll have some future proofing if you want to change your CPU later down the road.
            • #51
              Thanks Marty, 90312, thanks for the link also!
              But I'm still going after Quick Sync! I want the Z77 and i7-3770k!
