dvdfab bluray copy
    Software dvdfab bluray copy
    I have been trying for a month to get proper help with my( non working) software, and i keep geting the run around.I hope this is not censored. If they come out and tell me they are not going to help, I will just take the loss, and write the company, to try to get remibursed. Please help me please.
    bluray will not work.
    I bought dvdfab bluray copy. it will not work, and all other software on my computor works fine. I bought a bluray copy software called other software. It takes about 30 minutes to copy compress and write with no loss of quailty.MY COMPUTOR HAS ALL THE SPECS YOU NEED FOR DVDFAB. CAN ANYONE PLEASE HELP ME. THANK YOU MARCUS SAMMONS.
    Last edited by 90312; 02-03-2013, 01:45 AM. Reason: Naming other software here is bad form man!
      Some details would help us help you!
        details
        The software starts and scans fine and analizes fine. after that 6 hours later it has done nothing. I asked tecs to check my settings with no help. I asked if mabey I should uninstall and reinstall, wiyh no answer
          Hi marcsammo
          Please post your internal logs if any are generated.
          Thanks
          CBR929
