Hi there can some 1 please if they know answer to this Q im using dvdfab version 8.0.5.6 about 2 wks ago i swapped video cards, with old 1 when i was burning a bluray unless it was a 3 hr production with DTS TRUE HD MASTER etc it might take a few hrs but generally 2 hr productions and below normally about 1 hr or so, with this video card when its doing the encoding etc it comes up with CUDA GPU accelleration for video enabled ,, is that something thats to do with new version of dvd fab 8.0.5.6 or is that to do with my video card since changing ?? becourse now its taking twice as long
bluray Q need advise
It has to do with your video card changing. CUDA acceleration is a feature that is implemented on newer NVIDIA vid cards. If you could tell us your PC's specs, processor, video card before and video card after, we can tell you what's going on. Make sure you have the latest drivers for your new vid card also.SPECS
