If anyone wants a good laugh, just try to use DVDFab technical support. These guys are absolute clowns. If my tech support team was so incompetent, I would fire all of them. They have been troubleshooting an issue for over one month and have yet to even ask for the system logs...I had to offer them. Their only solution is blindly try installing the latest software version, over and over and over again.
Goodbye DVDFab...
Here is an example of a recent issue where I had to contact support:
Hi John,
Please install DVDFab 8.0.6.8 at .
Any questions in future, please feel free to contact us.
Sincerely yours,
cici Jia
DVDFab Support Team
Sent: Tuesday, January 04, 2011 4:20 AM
To: DVDFab support team
Cc: cici@dvdfab.com
Subject: Re: drive not recognized(Technical Support)
Hi Sunny,
I know you must be busy, but I am not sure that the support group at DVDFab is even bothering to READ THE PROBLEM DESCRIPTION. It is not a drive letter issue. DVDFab Version 7 works great. Every other program on my system works great. DVDFab Version 8 sees the drive as a VALID DESTINATION DRIVE, BUT NOT A VALID SOURCE DRIVE. We have wasted an entire month on this issue because nobody bothers to read the information I have repeatedly provided to Support.
Regards,
On 12/30/2010 5:00 AM, DVDFab support team wrote:
> Hi john,
> Please right click on My computer->Computer Management→disk manager, right click the your optical drive,change the driveletter or path to another like G, H, etc.
> Then restart computer, run DVDFab to see if the movie disc in your optical drive can be recognized correctly or not.
> Sincerely yours,
> Sunny Fan
> DVDFab Support Team
> From: Jon
> Sent: Wednesday, December 29, 2010 5:01 AM
> To: DVDFab Support Team
> Hi Cici,
> 8.0.5.6 does not work either. Yes, my DVD's play just fine on my PC. As I have said before, the DVD's also work just fine with DVDFab Version 7.x. Only 8.x does not work. It is obvious that SOMETHING THAT WAS CHANGED IN VERSION 8 IS THE PROBLEM. NOT MY DVD PLAYER, NOT THE DVD.
> At what point does this issue get escalated to engineering so my issue can be resolved? This ticket has been open for almost a month and I have been very patient. I think it is time that my issue is referred to another engineer. We are making absolutely no progress and now we are simply installing the latest version every day HOPING that the latest version will magically resolve the issue. As an IT professional, I understand that this is NOT how to resolve the problem.
> Let's move forward.
> Regards,
> On 12/28/2010 2:51 AM, DVDFab Support Team wrote:
>> Hi Jon,
>> 1.Please install DVDFab 8.0.6.5 at .
>> 2. Please make sure that your orginal DVD discs can play well on your computer with windows media player or another video player(such as VLC Media Player)
>> Sincerely yours,
>> cici Jia
>> DVDFab Support Team
>> From: Jon
>> Sent: Sunday, December 26, 2010 5:14 AM
>> Hi Cici,
>> I installed a new drive today, an ASUS DRW-24B3LT. The problem still occurs. DVDFab does not recognize the drive as a valid source. You may want to speak with engineering on this issue because it seems to be a much more widespread problem than just my system. I have read your forums and found numerous references to this same/similar problem.
>> Thanks,
>> On 12/22/2010 6:17 PM, Jon wrote:
>>> None of these suggestions work. I will try to buy a new drive and see if that drive is recognized by the software.
>>> Thanks,
>>> On 12/21/2010 4:08 AM, DVDFab Support Team wrote:
>>>> Hi Jon,
>>>> 1.Task1-error 400 means open movie files failed.
>>>> 2. Please click the tick green icon button at the right top corner of the DVDFab screen, open "Common Settings" window, click on "Pathplayer", deactive it to copy your movies again.
>>>> 3.Please use Main Movie option to copy and paste to see the result.
>>>> 4.Please open DVDFab first and then insert your disc to see whether DVDFab can recognize your drive or not.
>>>> 5.Please disable all the other players to see the result.
>>>> Sincerely yours,
>>>> cici Jia
>>>> DVDFab Support Team
>>>> From: Jon
>>>> Sent: Sunday, December 19, 2010 8:46 AM
>>>> Hi Cici,
>>>> Uninstalling and reinstalling does not resolve the problem. I have included additional information and the DVDFab log files. You can see from the below that DVDFab 8.0.6.1 does not see the drive either.
>>>> Below is what DVDFab sees the drive as on the Info page:
>>>> Info for drive [E:\] (DVDFab 8.0.6.1)
>>>> Drive region: 1
>>>> Drive region: 1
>>>> Disc type: Unknown
>>>> Disc is not opened.
>>>> dvdfab_process.log
>>>> dvdfab_burn_vso.log
>>>> dvdfab_internal.log
>>>> On 12/16/2010 11:47 PM, DVDFab Support Team wrote:
>>>>> Hi Jon,
>>>>> Please uninstall and reinstall DVDFab 8.0.6.0 at .
>>>>> We send you the key to use DVDFab 8 in the attachment, you just need double-click it to register directly. The key of DVDFab 8 is the same as the key of DVDFab7/DVDFab 6 now.
>>>>> Sincerely yours,
>>>>> cici Jia
>>>>> DVDFab Support Team
>>>>> From: Jon
>>>>> Sent: Wednesday, December 15, 2010 10:33 AM
>>>>> Hi Cici,
>>>>> Unfortunately none of these suggestions work. Strangely enough, DVDFab version 8x recognizes my drive as a valid TARGET destination, but will not recognize it as a valid SOURCE. I can burn stuff TO the drive using DVDFab version 8 without any problem. All other software on my machine works perfectly. The drive simply does not show up as a valid SOURCE in DVDFab version 8. It works perfectly with Version 7. Obviously DVDFab changed something in version 8 that conflicts with my drive: a Samsung SH-S223.
>>>>> Thanks
>>>>> On 12/11/2010 1:07 AM, DVDFab Support Team wrote:
>>>>>> Hi Jon,
>>>>>> 1. Please open DVDFab program first, then insert your original movie DVDs to your DVD drive, then to see if the DVDFab can connect your DVD drive to recognize the original DVDs or not.
>>>>>> If your DVDFab can't recognize original movies from DVD drive very well on your computer, please start the movie in your PC DVD Player (like PowerDVD) for a few seconds and then start the DVDFab analysis. Once the analysis starts, you can turn off the PC DVD player.
>>>>>> 2.Please click the tick green icon button at the right top corner of the DVDFab screen, open "Common Settings" window, click on "Pathplayer", active/deactive it to copy your movies again.
>>>>>> Sincerely yours,
>>>>>> cici Jia
>>>>>> DVDFab Support Team
>>>>>> From: Jon
>>>>>> Sent: Friday, December 10, 2010 8:46 PM
>>>>>> Hi Cici,
>>>>>> You are not understanding the problem. IT DOES NOT SEE THE DVD-ROM DRIVE. I CAN'T BURN ANYTHING WITH IT.
>>>>>> I can open folders on my desktop all day, I don't burn to/from my desktop, I burn to/from a DVD-ROM drive. Version 8 does not see the drive, Version 7 does.
>>>>>> Thanks,
>>>>>> On 12/7/2010 8:50 PM, DVDFab Support Team wrote:
>>>>>>> Hi Jon,
>>>>>>> Please click on the yellow folder to choose the moive manually to see the result.
>>>>>>> Sincerely,
>>>>>>> Cici Jia
>>>>>>> DVDFab Support Team
>>>>>>> From: Jon
>>>>>>> Sent: Wednesday, December 08, 2010 1:23 AM
>>>>>>> Hi Cici,
>>>>>>> Not sure how much additional information I can provide: You have my OS version, my drive type and firmware revision, and I have stated that the drive is fully recognized and supported by version 7.x of DVDFab, but is not recognized by any version of DVDFab 8.x.
>>>>>>> I have attached screenshots of the issue so you can see firsthand.
>>>>>>> Please let me know if you need additional information.
>>>>>>> On 12/7/2010 3:14 AM, DVDFab Support Team wrote:
>>>>>>>> Hi Jonathan,
>>>>>>>> You need to exactly describe your problem in detail. The more information you offer, the more effective assistance we provide.
>>>>>>>> Thanks for your understanding! We will try our best to help you.
>>>>>>>> Sincerely,
>>>>>>>> Cici Jia
>>>>>>>> From:
>>>>>>>> Sent: Monday, December 06, 2010 6:38 AM
>>>>>>>> To: "DVDFab" <service@dvdfab.com>
>>>>>>>> Subject: drive not recognized(Technical Support)
>>>>>>>>> Technical problem:copy_problem
>>>>>>>>> Operating System:Windows 2003 Server
>>>>>>>>> Software Version:8.0.5.6
>>>>>>>>> Software
VD to DVD
>>>>>>>>> DVD Copy mode:Full Disc
>>>>>>>>> DVD to play/copy:Any
>>>>>>>>> Message:
>>>>>>>>> Since upgrading to version 8.x, DVD Copy no longer recognizes my drive. Version 7.x of DVD Copy works properly.
>>>>>>>>> Drive is a Samsung SH-S223 with latest firmware.
>>>>>>>>> I am a licensed user of DVD Copy.
>>>>>>>>> Thanks,
Goodbye DVDFab...
Hi John,
Sincerely yours,
cici Jia
DVDFab Support Team
Cc: cici@dvdfab.com
Hi Sunny,
Regards,
> Hi john,
> Sincerely yours,
> Sunny Fan
> DVDFab Support Team
> From: Jon
> Hi Cici,
> Let's move forward.
> Regards,
>> Hi Jon,
>> Sincerely yours,
>> cici Jia
>> DVDFab Support Team
>> From: Jon
>> Hi Cici,
>> Thanks,
>>> Thanks,
>>>> Hi Jon,
>>>> Sincerely yours,
>>>> cici Jia
>>>> DVDFab Support Team
>>>> From: Jon
>>>> Hi Cici,
>>>> Drive region: 1
>>>> Drive region: 1
>>>> Disc type: Unknown
>>>> Disc is not opened.
>>>> dvdfab_process.log
>>>> dvdfab_burn_vso.log
>>>> dvdfab_internal.log
>>>>> Hi Jon,
>>>>> Sincerely yours,
>>>>> cici Jia
>>>>> DVDFab Support Team
>>>>> From: Jon
>>>>> Hi Cici,
>>>>> Thanks
>>>>>> Hi Jon,
>>>>>> Sincerely yours,
>>>>>> cici Jia
>>>>>> DVDFab Support Team
>>>>>> From: Jon
>>>>>> Hi Cici,
>>>>>> Thanks,
>>>>>>> Hi Jon,
>>>>>>> Sincerely,
>>>>>>> Cici Jia
>>>>>>> DVDFab Support Team
>>>>>>> From: Jon
>>>>>>> Hi Cici,
>>>>>>>> Hi Jonathan,
>>>>>>>> Sincerely,
>>>>>>>> Cici Jia
>>>>>>>> From:
>>>>>>>>> Software
>>>>>>>>> Message:
>>>>>>>>> Thanks,
