I had this problem weeks ago and stuck with version 5 until I needed to upgrade. Well now I need to.
I download the newest update. Install and run it. I also got my new registration code and entered that. It shows I am a lifetime version of DVD to DVD and DVD to mobile.
When I run the dvd6 and begin the copy process everything is fine.
I select main movie and begin to deselect languages and Swoooshsh, program quites. It does this every time I try. This is my third reinstall, and if i reinstall dvd5 everything works, but I can't copy Transformers 2 with out update.
I'm running xp. plenty of ram and hd.
THanks for help.
THanks for help.
