Buried Movie
    Buried Movie
    Can't Get It To Read All The Way Through..keeps saying Error.I have tried enabling and disabling pathplayer.have tried a few older versions of dvd fab but nothing is reqading pass the same point.If someone else has found a way please let me know.Thanks
    Sounds like a faulty/damaged/corrupt/dirty disk!!!!
    Please read maineman's thread in the Knowledge base.
      its gotta be a dirty dvd
        even if the dvd plays fine in my player?the disc is new.
          It does not matter if it plays in a DVD player ,as ripping and playing are totally different, because players are more forgiving when errors are encountered.
          If it is also new it does not matter, bad presses are very common.
          Here is the thread that GregiBoy was referring to
          To check if it is a bad disc, download VSO Inspector put the disc in your drive start Fab and let it open the disc and then start your scan to see if it says you have a bad disc.
          CBR929
            nope it cant be because i have 6 brand spanking new copy's from 6 places and not 1 have worked
            keep getting error 102 (cant read file)
            I'm using DVDFab v8.0.7.3
            I've also used the latest passkey 'no good what so ever' doesn't show the the disk just says error
            so i try other software hmmm needs to download update to read disk 'unfortunate only registered users can download updates' it shows protection is AACS v21
            so i know 6 disks ain't dirty
            so this has got to be software side
            ow the title is a uk version [upc=5051429702186]
              Buried
              I had no problem copying this one
                Did you follow the instructions in Post #5
                "To check if it is a bad disc, download VSO Inspector http://www.vso-software.fr/products/.../inspector.php put the disc in your drive start Fab and let it open the disc and then start your scan to see if it says you have a bad disc."
                CBR929
