DVD to .mov, how?
    DVD to .mov, how?
    Is there a way to convert DVD or segments to the codecs of Quicktime installed in my machine. I cannot figure how to do it. I also search links in the forum and nada! It seems that we are stuck with pre-selected codecs. Am I wrong?
    DVDFab 8.0.6.8 (05/01/2011)
    Win 7
    You cannot use codecs outside of Fab as they are built internally but to play with Quicktime, use one of the iPad/iPhone/Apple TV profiles and then you can adjust the parameters within.
      Thank you GregiBoy. That's what I was afraid of.
