Problems with 8.0.7.3
    The new version 8.0.7.3 can not open, or Microsoft has encountered a problem and needs to close the program.
    if I run DVDFab 8.0.5.0 from November 18 so I have no problems
    Is there anyone who can help me with it, so I can get the latest version and get it to work okay
    I'm running Vista 32 bit Processer: AMD Turion 64 x2 mobile technology TL-60 2.00 ghz Ram 4 gb
    Peter
    Denmark
    Update to V8.0.7.6
      I too have same probs,
      Peter
      Denmark
      Hi Peter, I've just spent over an hour taking off uninstalling and re-installing to see if that would help, I'm also running Vista 32bit had no probs with the eartlier ones, and have downloaded 8.0.7.6. and shall try to install to see if goes OK...I too cannot seem to stop Microsoft from shutting the program down. Any-one out there can help us...please...tx
        DVDFab 8.0.7.3 is out (January 29, 2011)
        Same issues with me trying beta version now. this version refuses to open
          Were the installers installed as Administrator???
          Instead of clicking run click save then open the folder and right click and install the program as administrator.
          You may also try right clicking the desktop icon and click run as administrator.
          Also check you virus program to make sure that it is not quarantining Fab.
          Hope this helps
          CBR929
            Give this a read:
              I have read and have also tried it. But it still does work
                That means you could run dvdfab on your Vista 32 bit Processer normally.
                Please go to C:\Users\User Name\Documents\DVDFab, delete all the files under this DVDFab folder. Then redownload DVDFab 8073 at
                install and run to see the result.
