Hardware needs
    CPU/GPU Hardware needs
    Is the Level 2 or even Level 3 cache (AMD) of the same importance as the amount of processor cores? For example: Athlon X4 versus Phenom X4?
    Thx in advance
    Go for the number of cores and the clock speed of the CPU. The cache is not as important as those two.
      I did some testing using a Intel Core2Duo dualcore E7200 8GB DDR2-800 pc under Windows 7 64-bit and also a Pentium Dualcore E6700 6GB DDR2-1066 pc under Windows 7 64-bit. A friend of mine did the same ripping with a quadcore Intel Q8400 (4GB DDR2-800) under Windows XP. And guess what? Ripping to AVI (Divx/Xvid) was only a few minutes quickier with the quadcore than with both dualcores. We uses DVDFab 8.0.2.2.
      What went wrong?
      Thx in advance
        Do the compare using an h.264 profile that utilizes multiple cores.
          Aha!
          Is Divx/Xvid only using dualcore? Problem wit H.264 is the lack of compatibility with several devices. That's why I don't like/use it. It is also much slower in converting.
            I will include a couple screenshots, one DivX and one h.264. You'll see the Divx never fully utilizes the cores where the h.264 does.
