Im thinking about purchasing a Blu-Ray burner, since I have a Playstation 3.
I was thinking about getting the following one. The reviews have been good, and 10x is decent burning speed (I don't really care how fast stuff burns).
Also, I was going to get these Verbatim BD-R LTH discs. I've used Verbatim DVD's for ages, without burning/playback issues. These discs have good reviews, a couple people have said they have had issues with them, but it seems as if that was just a Firmware issue. Plus Verbatim says it works with the burner I want to buy, and the Playstation 3 (which i'll be using to play).
I was just wondering if this would be a good choice? Like I said, the reviews are good for both, but was looking for input from people experienced with this. Last thing I want to do, is buy a burner and discs, and have a bunch of flukes coming out. At $2.00/disc, that's something I REALLY want to avoid.
Also, i'll be using DVDFab to rip the blu-ray discs . DVDFab works around that Cineva protection correct?
