conversion profiles
    conversion profiles
    What do the different profiles mean for the different conversion types?
    Is there any listing anywhere that says what each profile does and which one is the best to use ?
    Is it just trial and error ?
    thanks
    Depends on what your target playing device is for a start!
      PC is my main target
      But I may expand my horizons at some time.
      I was hoping for a table of some sorts to point me in the right direction.
      Or some primer I can read that would make sense.
      There are different formats and then several profiles under them.
      I am trying to figure out which combination is the best to rip with
      thanks
      --Bill
        No table, no primer, etc (unfortunately)
        I would start off with MKV H264 Audiocopy and go from there. My "Best Practice" thread (Link in my signature below) may also be worth a read to give you some clues.
          Hi slacker
          Agreed GregiBoy's "Best Practice" will be your starting point and when you decide to expand your horizons he is the most knowledgeable in this field.
          Make sure to do a little homework on your part on what you want to achieve in expanding your horizons (use Google) and I'm sure that GregiBoy will help you if you hit a wall.
          CBR929
