New Versions won't even start/load
    Updated to the new QT versions...even Beta, but neither will even load on my WinXP machine. I can't figure it out, the older versions worked fine...unistalled them and installed the new ones and nothing. Anyone else have this problem? Not sure which direction to even take since you can see it trying to exectute dvdfab.exe in Windows task manager and after a few seconds it just disappears...
    nvidia/ati graphics card? Checked that the latest version of drivers for that card is installed?
    You don't need to uninstall the old versions as the QT versions installs in a separate program folder.
      Is the latest version you are trying 8.0.9.6 Beta?
      人生は贈り物であり、完全な喜びを経験する必要があります
        I am having the same problem with the QT install under Windows XP. I am running XP SP3, with a Nvidia GeForce FX 5600 Ultra display video card with Nvidia's latest driver (175.19 WHQL) driver. I was able to successfully run DVDFAB (non QT) version, so there really seems to be an issue with some XP systems. As part of my trouble shooting, I completely uninstalled the working (non QT) version of DVDFAB (think it was v8.0.8.5). So can someone point me to this download, as I did not archive that version? I can only seem to find the latest QT build from your site.
        To be perfectly clear, regressing to v8.0.8.5 is ONLY a stopgap measure until your development team comes up with a fix for these XP systems. Stating check that you are running the latest Nvidia driver is logical and I have done that, so what's next?
        Thanks
        Ken
          Hi kc7457
          You will find older versions here
          CBR929
            Hi kc7457
            CBR929
            Thanks CBR929.
            And to help the developers, the original QT version I installed was v8.0.9.2. This version and the Beta I just downloaded (v8.0.9.6) also does not work on my XP system.
            There seems to be several (not linked) topics on this subject. Can you, the Moderator, create a sticky link that will allow all affected users to report / assist with the solution?
            For now, I will use v8.0.8.5, but I am seeking an XP solution for the QT iteration.
            Thanks
            Ken
              V 8097 has been released.
                I would call it the final version.
                Version: 175.16 WHQL
                Release Date: 2008.05.16
                Operating System: Windows XP
                  Thank you for the latest Beta, but even version 8097 does not correct the XP / QT "issue". Please advise those affected XP users what to do next to assist with a fix.
                  Regards,
                  Ken
                    Regards,
                    Ken
                    V8098 has been released.
                      yes having same problem 8098 errors out every time and wont load, have tried multiple times to download it, XP sp3
                        Have been posting on this does not work with 6 Core 1090T AMD at all since 8.3 when they changed engine and now does not work on my other xp system ether. Lifetime upgrades do not help if you break the working features in the process. And the features being added I do not use now and why would I invest more with what I am seeing? Have not seen any responds from Fengtao on this at all.
                          And that still doesn't work on XP SP3 machines
                          Paid Not To Work
                          US Navy Retired ( 20 Years )
                          Proudly Served On
                          USS Coral Sea CVA-43 (VF-154) / USS Oriskany CVA-34 (VFP-63) / USS Ranger CVA-61 (VF-121)
                          6 trips to the Gulf Of Tonkin
                            this is the info I got from the error report whan the newest download of 8098 wouldnt open
                            AppName: dvdfab.exe
                            AppVer 8.0.9.8
                            ModName: nscore.dll
                            ModVer 5.2.7.18
                            Offset: 00009148
                            Exception Information
                            Code: Ox0000005
                            Flsgs: Ox00000000
                            Record: 0x0000000000000000
                            Address: Ox0000000061089148
                            System Information
                            Windows NT 5.1 Build 2600
                            CPU Vendor Code 68747541-69746E65 - 444D4163
                            Cpu Version 000000681 CPU Feature Code 0383fbff
                            Cup AMD Feature Code : C1CBFbFF
                            Module 1
                            DVDFab.exe
                            Image Base 0x00400000 Image Size 0x00000000
                            Checksum: Ox006814ed Time Stemp Ox4def5a90
                            Version Information
                            signature feef04bd
                            StrucVer: 00010000
                              AppName: dvdfab.exe
                              AppVer 8.0.9.8
                              ModName: nscore.dll
                              ModVer 5.2.7.18
                              Offset: 00009148
                              Code: Ox0000005
                              Flsgs: Ox00000000
                              System Information
                              Module 1
                              DVDFab.exe
                              Version Information
                              signature feef04bd
                              StrucVer: 00010000
                              There was another user with the same problem as you. Disable the program you got from NielsenOnline (the bar code reading) while you install and run DVDFab.
