New Versions won't even start/load
    I am having the same problem installing the QT dvdfab programs on my XP machine. SP3 updated drivers and all updates for xp. When I go to install any QT program it goes all the way to the end then stops. If I goto system processes and stop the dvdfab.exe it will finish installing. When I try to run the QT program the dvdfab.exe comes on in processes and nothing else happens. 8092qt, 8097qt, and 8098qt all respond the same to install and run. Also I cannot uninstall them at all. Hopefully someone can figure the fix for XP and dvdfab compatability problems. I am currrently running fine on 8085. No probs there. Thanks for any advice.
      In fact, ANY program which has the file nscore.dll and it's running in the background, disable it (or unstall the program) and everything should be fine.
        sorry for the bad post. My nvidia driver was not current. that fixed the problem.
          Originally posted by Gruñón View Post
          V8098 has been released.
          I have installed your latest (non Beta) release, v8098. It does NOT fix my XP problem. If you recall I am running a GeForce FX 5600 Ultra with the latest / last driver driver (175.19 WHQL). So I will ask again, what more do you need (from me) to fix this problem? We are all adults here, so if you do not plan to support XP, tell us. I do plan to build a new Windows 7 based system later this year since I realize my current sysytem is nearing its technological end, but since you advertise XP support and since I paid darn good $$$ for this software, I do expect you to address this.
          Please do not imply to run the latest software (which I have done twice now) as a "solution". This is quite frustrating, especially when none of your current "QT" versions seem to work on my XP system.
          Regards,
          Ken
            8097qt worked for me
            I had not been able to get any of the QT versions to do a successful blu-ray copy on my XPpro, SP3 machine. I am very happy to report that the last version I used, 8097qt, worked. Just wanted to share with the builder that this version appears to have solved my issues with QT.
              Regards,
              Ken
              When you say "you" are you addressing me personally?
              If so........
              I do not work for DVDFab.
              It is not my software.
              I do not develop / repair / fix or have anything else to do with the writing or selling of the software.
              I use Win XP Pro Sp 3 and do not have a problem with the QT versions.
              When I post that a new version has been released I do not care if you try it or not. That is your choice . I am simply posting that there is a new version available.
                Hi all,
                Here is a post from versions ago that a member had problems going from version 7 to 8.
                NOTE: This is not for everyone, if you are not comfortable going into you registry, by all means do not do it.
                You take full responsibility for any changes that you make to your computer.
                This is what they said.
                I recently had an issue after upgrading from version 7 to version 8 where DVDFab would not start at all. After some messing around with trying to install with anti virus off and multiple uninstalls and reinstalls of previous versions, I decided to check within the registry. Now, for those not comfortable messing with registry settings, I would advise you ask a computer tech, who is, to do the following changes. To enter the registry go to the start menu and select run, from there type regedit. This will open up the registry. You are going to want to be in HKEY_CURRENT_USER then go into Software. Once in Software, find DVDFab and check the Path in the window on the right. It should show something like this C:\Program Files\DVDFab #\DVDFab.exe where DVDFab # is whatever current version you have installed. Mine was showing DVDFab 7 so when I would click on the desktop icon, quick launch or even the .exe within the DVDFab folder, it was looking for version 7 and would not launch 8. Hope this is a help to anyone that is having issues with DVDFab opening.
                The only thing I see different in their post is that there is no DVDFab.exe, I think you will be looking at the DVDFab application file.
                Here is something else to try for those of you trying the capability.
                Go into properties of the icon under compatibility, uncheck all but check turn off text services and check disable visual themes and give it a try.
                Hope this may help you.
                CBR929
                  There is no easy solution to this problem I have tried everything under the sun. I had to go and do a clean install of Windows XP pro and loaded SP3 then my video Nivida drivers and then installed DVDFab QT and now it works. I guess they will not find a fix as Windows XP will soon be fazed out and 7 will be the basic OS for now. What is strange I use this system as a stand alone for DVFAb only and had prior versions going way back so it must have something to do with the newer version not running. Like I said a clean install solved the problem. Lots of work if you have lots of programs on your system but mind was a stand alone for DVDFab and got it all back within an hour.
                    Thank you for this update. Unfortunately I have way too many other files / applications to perform a "clean" install. I do run Acronis 2011 backup religiously and have reverted to a image a couple of months ago (before any QT versions were installed) and this did NOT correct the problem either. I even tried the suggestions (Regedit, etc) a few posts ago from the "Moderator", CBR929, and none of those suggestions worked.
                    What I really would like to know is the formal support process for this software. I have paid for this software, so I believe I am entitled to some rudimentary support. If this support is forum based only, I am using the correct protocol? I run my own business, so I realize that not many resources will be placed on XP product development for what is arguably a retired OS, but since DVDFab still advertises XP compatibility, I am looking for some developer support. I have asked previously if my (forum) question should be posted somewhere else or if there should be a unique "sticky" thread to track this issue. I suspect most purchasers are Win7 based, hence the lack of a large affected population base. Very perplexing, indeed, since all the "pre" QT versions worked GREAT. Still open for suggestions, but I do realistically understand my OS platform is in the minority - development cycles wise.
                    Ken
                      Hi all,I'm having the same problem with XP SP3 DvdFab not starting up,Ati video,all latest drivers etc.Using DvdFab 8.0.9.8 qt,Mine will start like every 3 times I click on the icon and work ok from there.The first time I click on it to start,I get a message Dvdfab has encountered a problem and needs to close.I try it 2-3 times more and it will eventually start and work.I hope future update's work better than this.At least I can get it to work,after 2-3 times? Weird Xp Sp3 Problem.No one else seems to be having this problem,Hope they can fix it.
                        Any more details about what is the specific problem?
                          DvdFab just won't start,If I click on the icon like 3 separate times the program starts up and works fine.Will not start up the first time.Comes up with the saying DvdFab has encountered a problem,and needs to close,after the 3rd time or so,starts up ok.Weird?
                            Isn't there any more info when it crashes in the window that tells you that it has encountered a problem? Like it crashed due to an error in file x?
                              ok,No errors on found DvdFab Reports.
                              ok,this is what I get when I start DvdFab,The application has encountered a
                              problem and needs to close message. 3-4 times,then starts ok and runs ok,till next start,does the same thing.
                              Error report contains:
                              AppName: dvdfab.exe AppVer: 8.0.9.8 ModName: unknown
                              ModVer: 0.0.0.0 Offset: 00000000
                              Code:
                              Technical Information on the error:Some of it anyway.
                              <?xml version="1.0" encoding="UTF-16"?>
                              <DATABASE>
                              <EXE NAME="DVDFab.exe" FILTER="GRABMI_FILTER_PRIVACY">
                              <MATCHING_FILE NAME="avcodec.dll" SIZE="6748695" CHECKSUM="0xD2A4E896" MODULE_TYPE="WIN32" PE_CHECKSUM="0x67125E" LINKER_VERSION="0x10000" LINK_DATE="05/12/2011 05:04:33" UPTO_LINK_DATE="05/12/2011 05:04:33" />
                              <MATCHING_FILE NAME="avcore.dll" SIZE="55312" CHECKSUM="0xBF967893" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1D62C" LINKER_VERSION="0x10000" LINK_DATE="05/12/2011 04:45:06" UPTO_LINK_DATE="05/12/2011 04:45:06" />
                              <MATCHING_FILE NAME="avformat.dll" SIZE="904380" CHECKSUM="0x1BA54599" MODULE_TYPE="WIN32" PE_CHECKSUM="0xEB7D1" LINKER_VERSION="0x10000" LINK_DATE="05/12/2011 05:05:45" UPTO_LINK_DATE="05/12/2011 05:05:45" />
                              <MATCHING_FILE NAME="avutil.dll" SIZE="148648" CHECKSUM="0x27CBBDF3" MODULE_TYPE="WIN32" PE_CHECKSUM="0x30E76" LINKER_VERSION="0x10000" LINK_DATE="05/12/2011 04:21:46" UPTO_LINK_DATE="05/12/2011 04:21:46" />
                              <MATCHING_FILE NAME="codecs.dll" SIZE="2456714" CHECKSUM="0xFD81CD8D" MODULE_TYPE="WIN32" PE_CHECKSUM="0x25A342" LINKER_VERSION="0x10000" LINK_DATE="05/20/2011 09:40:23" UPTO_LINK_DATE="05/20/2011 09:40:23" />
                              <MATCHING_FILE NAME="CrashRpt.dll" SIZE="78336" CHECKSUM="0xAC4FEAA3" BIN_FILE_VERSION="5.0.0.3" BIN_PRODUCT_VERSION="5.0.0.3" PRODUCT_VERSION="5, 0, 0, 3" FILE_DESCRIPTION="DVDFab - Crash Report Module" COMPANY_NAME="Fengtao Software Inc." PRODUCT_NAME="DVDFab - Crash Report Module" FILE_VERSION="5, 0, 0, 3" ORIGINAL_FILENAME="CrashRpt.dll" INTERNAL_NAME="CrashRpt.dll" LEGAL_COPYRIGHT="Copyright (C) 2010 Fengtao Software Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="5.0.0.3" UPTO_BIN_PRODUCT_VERSION="5.0.0.3" LINK_DATE="10/09/2010 03:43:12" UPTO_LINK_DATE="10/09/2010 03:43:12" VER_LANGUAGE="English (United States) [0x409]" />
                              <MATCHING_FILE NAME="dbghelp.dll" SIZE="640000" CHECKSUM="0xF61A4561" BIN_FILE_VERSION="5.1.2600.5512" BIN_PRODUCT_VERSION="5.1.2600.5512" PRODUCT_VERSION="5.1.2600.5512" FILE_DESCRIPTION="Windows Image Helper" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Windows® Operating System" FILE_VERSION="5.1.2600.5512 (xpsp.080413-2105)" ORIGINAL_FILENAME="DBGHELP.DLL" INTERNAL_NAME="DBGHELP.DLL" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xAB3A7" LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.5512" UPTO_BIN_PRODUCT_VERSION="5.1.2600.5512" LINK_DATE="04/14/2008 00:09:22" UPTO_LINK_DATE="04/14/2008 00:09:22" VER_LANGUAGE="English (United States) [0x409]" />
                              <MATCHING_FILE NAME="DVDFab.exe" SIZE="6783992" CHECKSUM="0x615B8B87" BIN_FILE_VERSION="8.0.9.8" BIN_PRODUCT_VERSION="8.0.9.8" PRODUCT_VERSION="8, 0, 9, 8" FILE_DESCRIPTION="DVDFab is the all-in-one software package for copying Blu-ray/DVD and converting video file." COMPANY_NAME="Fengtao Software Inc." PRODUCT_NAME="DVDFab" FILE_VERSION="8, 0, 9, 8" ORIGINAL_FILENAME="DVDFab.exe" INTERNAL_NAME="DVDFab.exe" LEGAL_COPYRIGHT="Copyright (C) 2001-2011 Fengtao Software Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x67FEB9" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="8.0.9.8" UPTO_BIN_PRODUCT_VERSION="8.0.9.8" LINK_DATE="06/09/2011 10:07:10" UPTO_LINK_DATE="06/09/2011 10:07:10" VER_LANGUAGE="English (United States) [0x409]" />
                              <MATCHING_FILE NAME="DVDFabShellEx.dll" SIZE="10752" CHECKSUM="0xFBFD6BC0" BIN_FILE_VERSION="2.0.1.0" BIN_PRODUCT_VERSION="2.0.1.0" PRODUCT_VERSION="2.0.1.0" FILE_DESCRIPTION="DVDFab Shell Extension - x86" COMPANY_NAME="Fengtao Software Inc." PRODUCT_NAME="DVDFab Shell Extension" FILE_VERSION="2.0.1.0" ORIGINAL_FILENAME="DVDFabShellEx.dll" INTERNAL_NAME="DVDFabShellEx" LEGAL_COPYRIGHT="Copyright (C) 2001-2010 Fengtao Software Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x3281" LINKER_VERSION="0x50002" UPTO_BIN_FILE_VERSION="2.0.1.0" UPTO_BIN_PRODUCT_VERSION="2.0.1.0" LINK_DATE="01/06/2011 02:31:56" UPTO_LINK_DATE="01/06/2011 02:31:56" VER_LANGUAGE="English (United States) [0x409]" />
                              <MATCHING_FILE NAME="FabCore.exe" SIZE="488952" CHECKSUM="0x7A45936B" BIN_FILE_VERSION="1.0.5.1" BIN_PRODUCT_VERSION="1.0.5.1" PRODUCT_VERSION="1, 0, 5, 1" FILE_DESCRIPTION="FabCore" COMPANY_NAME="Fengtao Software Inc." PRODUCT_NAME="DVDFab" FILE_VERSION="1, 0, 5, 1" ORIGINAL_FILENAME="FabCore.exe" INTERNAL_NAME="FabCore.exe" LEGAL_COPYRIGHT="Copyright (C) 2001-2009 Fengtao Software Inc. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x86939" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.5.1" UPTO_BIN_PRODUCT_VERSION="1.0.5.1" LINK_DATE="06/07/2011 07:58:23" UPTO_LINK_DATE="06/07/2011 07:58:23" VER_LANGUAGE="English (United States) [0x409]" />
                              <MATCHING_FILE NAME="FabReport.exe" SIZE="485368" CHECKSUM="0x77BD7DA6" MODULE_TYPE="WIN32" PE_CHECKSUM="0x7E77E" LINKER_VERSION="0x0" LINK_DATE="04/02/2011 03:42:41" UPTO_LINK_DATE="04/02/2011 03:42:41" />
                              <MATCHING_FILE NAME="FileMover.exe" SIZE="1134384" CHECKSUM="0x8B1CE08F" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1169E0" LINKER_VERSION="0x0" LINK_DATE="06/03/2011 06:31:48" UPTO_LINK_DATE="06/03/2011 06:31:48" />
                              <MATCHING_FILE NAME="MediaInfo.dll" SIZE="1703424" CHECKSUM="0x967E93D8" BIN_FILE_VERSION="0.7.35.0" BIN_PRODUCT_VERSION="0.7.35.0" PRODUCT_VERSION="0.7.35.0" FILE_DESCRIPTION="All about your audio and video files" COMPANY_NAME="MediaArea.net" PRODUCT_NAME="MediaInfo" FILE_VERSION="0.7.35.0" ORIGINAL_FILENAME="MediaInfo.dll" INTERNAL_NAME="MediaInfoLib - DLL - MSVC 2008" LEGAL_COPYRIGHT="MediaArea.net" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="0.7.35.0" UPTO_BIN_PRODUCT_VERSION="0.7.35.0" LINK_DATE="10/09/2010 07:55:44" UPTO_LINK_DATE="10/09/2010 07:55:44" VER_LANGUAGE="English (United States) [0x409]" />
                              <MATCHING_FILE NAME="mgwz.dll" SIZE="56832" CHECKSUM="0xD7ABAC13" MODULE_TYPE="WIN32" PE_CHECKSUM="0x18928" LINKER_VERSION="0x10000" LINK_DATE="09/06/2003 07:43:12" UPTO_LINK_DATE="09/06/2003 07:43:12" />
                              <MATCHING_FILE NAME="msvcp90.dll" SIZE="552952" CHECKSUM="0xA92CD341" BIN_FILE_VERSION="9.0.0.0" BIN_PRODUCT_VERSION="9.0.0.0" PRODUCT_VERSION="9.00.0000" FILE_DESCRIPTION="User-Generated Microsoft (R) C/C++ Runtime Library" COMPANY_NAME="Fengtao Software Inc." PRODUCT_NAME="User-Generated Microsoft (R) C/C++ Runtime Library" FILE_VERSION="9.00.0000" ORIGINAL_FILENAME="msvcp90.dll" INTERNAL_NAME="msvcp90.dll" LEGAL_COPYRIGHT="Copyright (C) Microsoft Corporation." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x8CF58" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="9.0.0.0" UPTO_BIN_PRODUCT_VERSION="9.0.0.0" LINK_DATE="04/18/2011 12:55:23" UPTO_LINK_DATE="04/18/2011 12:55:23" VER_LANGUAGE="English (United States) [0x409]" />
                              <MATCHING_FILE NAME="msvcr90.dll" SIZE="650744" CHECKSUM="0x2442DF15" BIN_FILE_VERSION="9.0.0.0" BIN_PRODUCT_VERSION="9.0.0.0" PRODUCT_VERSION="9.00.0000" FILE_DESCRIPTION="User-Generated Microsoft (R) C/C++ Runtime Library" COMPANY_NAME="Fengtao Software Inc." PRODUCT_NAME="User-Generated Microsoft (R) C/C++ Runtime Library" FILE_VERSION="9.00.0000" ORIGINAL_FILENAME="msvcr90.dll" INTERNAL_NAME="msvcr90.dll" LEGAL_COPYRIGHT="Copyright (C) Microsoft Corporation." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xA7D5E" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="9.0.0.0" UPTO_BIN_PRODUCT_VERSION="9.0.0.0" LINK_DATE="04/18/2011 12:54:14" UPTO_LINK_DATE="04/18/2011 12:54:14" VER_LANGUAGE="English (United States) [0x409]" />
                              <MATCHING_FILE NAME="pthreadGC2.dll" SIZE="73382" CHECKSUM="0x19D1090E" BIN_FILE_VERSION="2.8.0.0" BIN_PRODUCT_VERSION="2.8.0.0" PRODUCT_VERSION="2, 8, 0, 0" FILE_DESCRIPTION="POSIX Threads for Windows32 Library" COMPANY_NAME="Open Source Software community project" FILE_VERSION="2, 8, 0, 0" ORIGINAL_FILENAME="pthreadGC" INTERNAL_NAME="pthreadGC" LEGAL_COPYRIGHT="Copyright (C) Project contributors 1998-2004" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x1A0BA" LINKER_VERSION="0x10000" UPTO_BIN_FILE_VERSION="2.8.0.0" UPTO_BIN_PRODUCT_VERSION="2.8.0.0" LINK_DATE="05/30/2009 13:30:52" UPTO_LINK_DATE="05/30/2009 13:30:52" VER_LANGUAGE="English (United States) [0x409]" />
                              <MATCHING_FILE NAME="QtCore4.dll" SIZE="2554880" CHECKSUM="0x898452F9" BIN_FILE_VERSION="4.7.2.0" BIN_PRODUCT_VERSION="4.7.2.0" FILE_DESCRIPTION="C++ application development framework." COMPANY_NAME="Nokia Corporation and/or its subsidiary(-ies)" PRODUCT_NAME="Qt4" FILE_VERSION="4.7.2.0" ORIGINAL_FILENAME="QtCore4.dll" LEGAL_COPYRIGHT="Copyright (C) 2011 Nokia Corporation and/or its subsidiary(-ies)." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x40048" UPTO_BIN_FILE_VERSION="4.7.2.0" UPTO_BIN_PRODUCT_VERSION="4.7.2.0" LINK_DATE="06/06/2011 12:25:52" UPTO_LINK_DATE="06/06/2011 12:25:52" />
                              <MATCHING_FILE NAME="QtGui4.dll" SIZE="9036288" CHECKSUM="0x28259F15" BIN_FILE_VERSION="4.7.2.0" BIN_PRODUCT_VERSION="4.7.2.0" FILE_DESCRIPTION="C++ application development framework." COMPANY_NAME="Nokia Corporation and/or its subsidiary(-ies)" PRODUCT_NAME="Qt4" FILE_VERSION="4.7.2.0" ORIGINAL_FILENAME="QtGui4.dll" LEGAL_COPYRIGHT="Copyright (C) 2011 Nokia Corporation and/or its subsidiary(-ies)." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x40048" UPTO_BIN_FILE_VERSION="4.7.2.0" UPTO_BIN_PRODUCT_VERSION="4.7.2.0" LINK_DATE="05/18/2011 08:12:13" UPTO_LINK_DATE="05/18/2011 08:12:13" />
                              <MATCHING_FILE NAME="RegOperator.exe" SIZE="23032" CHECKSUM="0x452ABEC5" MODULE_TYPE="WIN32" PE_CHECKSUM="0xDDD8" LINKER_VERSION="0x0" LINK_DATE="12/13/2010 11:25:54" UPTO_LINK_DATE="12/13/2010 11:25:54" />
                              <MATCHING_FILE NAME="unins000.exe" SIZE="710648" CHECKSUM="0x3310E736" BIN_FILE_VERSION="51.52.0.0" BIN_PRODUCT_VERSION="0.0.0.0" FILE_DESCRIPTION="Setup/Uninstall" FILE_VERSION="51.52.0.0" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0xB75D0" LINKER_VERSION="0x60000" UPTO_BIN_FILE_VERSION="51.52.0.0" UPTO_BIN_PRODUCT_VERSION="0.0.0.0" LINK_DATE="06/19/1992 22:22:17" UPTO_LINK_DATE="06/19/1992 22:22:17" VER_LANGUAGE="Language Neutral [0x0]" />
                              <MATCHING_FILE NAME="vso_hwe.dll" SIZE="2553120" CHECKSUM="0x2FCDF50A" BIN_FILE_VERSION="4.0.19.487" BIN_PRODUCT_VERSION="4.0.19.487" PRODUCT_VERSION="4.0.16.0" FILE_DESCRIPTION="CD/DVD writing engine" COMPANY_NAME="VSO Software" PRODUCT_NAME="Vso Headless Writing Engine" FILE_VERSION="4.0.19.487" ORIGINAL_FILENAME="" INTERNAL_NAME="vso_hwe" LEGAL_COPYRIGHT="2003-2011 VSO Software" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x272E56" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="4.0.19.487" UPTO_BIN_PRODUCT_VERSION="4.0.19.487" LINK_DATE="05/31/2011 15:04:34" UPTO_LINK_DATE="05/31/2011 15:04:34" VER_LANGUAGE="French (France) [0x40c]" />
                              <MATCHING_FILE NAME="zlibwapi.dll" SIZE="65536" CHECKSUM="0x11C3CEE9" BIN_FILE_VERSION="1.2.3.0" BIN_PRODUCT_VERSION="1.2.3.0" FILE_DESCRIPTION="zlib data compression library" PRODUCT_NAME="ZLib.DLL" FILE_VERSION="1.2.3.0" ORIGINAL_FILENAME="zlib.dll" INTERNAL_NAME="zlib" LEGAL_COPYRIGHT="(C) 1995-2003 Jean-loup Gailly &amp; Mark Adler" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x10004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x10017" UPTO_BIN_FILE_VERSION="1.2.3.0" UPTO_BIN_PRODUCT_VERSION="1.2.3.0" LINK_DATE="10/09/2010 03:46:33" UPTO_LINK_DATE="10/09/2010 03:46:33" VER_LANGUAGE="English (United States) [0x409]" />
                              Can't paste all of file to big.
                                Tried uninstalling completely,and doing a clean install.Still same problem in XP SP3.Have a Athlon 64 X2 4400+,2Gig Ram,and a Ati X1950 Pro 512MB Video.Latest Drivers for that video Card,etc..Have DvdFab 8.1.0.0 Qt Installed,and I have to click on the icon 3-4 times,one at a time,then it will startup,and run ok..1st time I click on it,I get the The Application has encountered a problem and needs to close.2nd time same thing,3rd time same thing,4th time start up ok,and runs ok...No errors in DvdFab,What is up with this?? Will there be a fix for us XP SP3 people out here? Anyone else having this problem?
