Split a movie based on time instead of chapter?
    Is there anyway to split a movie based on time instead of chapter? Like if I want to remove an intro to a TV show, but the first chapter doesn't line up correctly. Normally I can just select "Chapters 2-7" or something, but this doesn't work if the chapters don't line up correctly.
    Is there a way to do it based on time?
    Thanks.
    not yet
    Windows 7 64bit ultimate
    CPU: i7 4770K @4.5 vcore@1.28v temps 27c/67c
    RAM: 16GB DDR3 @2133
    GPU: nVIDIA GeForce GTX 770 2GB
    SSD: 2 X 60GB OCZ vertex 3 RAID 0 (boot drive)
    HHD: 1 TB WD BLK (storage and back up)
    PSU: 760W ,Fans 1x200mm and 2x120mm
      Hi tyrindor
      I have moved you post from Blu-Ray to the approiate section for this kind of question.
      CBR929
        Hi tyrindor
        CBR929
        Sorry about that.
        May need to move it again, since this is technically now a feature request thread.
          Hi tyrindor
          This has been asked many times before and is on their "to do list" but no time frame when it will be available.
          CBR929
